We removed the trees pushing this wall over a few months ago and had to wait until now to get TM in place to remove wall and destump.
Dozens of big stumps to dig out and 200mts of leaning/cracked wall ranging in height from four to six feet.
6298F21D-703E-4D86-B750-52D6560B7CF7_zps
C332DE6B-5951-45AE-8893-A975E055C595_zps
0E190A5D-4EED-4198-A02C-8A49ED195751_zps
D982B67D-48BC-4F5E-BFAD-1796BC417661_zps
ADE33F30-8F32-4DD1-8CEB-84D2162129BE_zps
E100C02C-D68D-46C6-B28E-B5285D7A4AEE_zps
Furious day but all done by 4pm, just grading and clean up tomorrow.
7C950653-B7A9-47CE-914B-53FCC402BAE0_zps
27 minutes ago, Steve Bullman said:
bit dangerous mate, he doesn't even have chainsaw trousers on!
Hows that grinder?
I like the grinder. it does take some getting used to with the loader, you can use the steering to sweep left to right or use the tilt to sweep in an arc up and down or use the boom to sweep in and out. if you can understand that?! its very smooth and you have a perfect view of what you are grinding. Only 23hp could do with 27 ideally but they wouldn't do it.
I was looking for a grinder for a while but couldn't justify the 10k for dedicated machine, the klou one was 3.5k and utilises my loader.
70’ multi stem sycamore in a tight spot, no fewer than 7 sheds with fragile roofs underneath, thankfully there was one air raid shelter with a concrete roof which served as a landing pad . Not massive but just about every single piece needed rigging.
Really felt my age at the the end of it.
On 29/05/2018 at 19:39, shillo said:
Some from the last few weeks
Can you fit that grinder to a mini digger?
