Nothing illegal about beadlockers per se but they need to be 'E'-marked, and I believe that the only 'E'-marked 16" beadlockers are the Hutchinson ones at around €525 apiece.
If I recall correctly from when I had similar thoughts the Tibus portals cost about £1000 per corner.
I'm toying with the idea of installing Tibus Portal Hubs to my 2004 130....[ATTACH]220963[/ATTACH]
The bolt on portals look a lot less work & agg of putting mog or ex military portals under a landrover
What the cost of these ? It's something I'd be interested in myself
The Tibus Portal Hubs are not cheap.
Had a quote: €10,000 for Hubs and brakes. Hutchinson beadlock 5-bolt 7x16 rims are €400 each.
Takes 8hrs to fit.
thats a lot of money!! do you find that your normal landrover set up wont do what you want off road that often?? just wondering.
thanks carl
That's a lot of money, I was expecting 4 grand but 10 !! shame as these bolt on portals will be so much lighter then military axels
For my landrover portals are worth is as I use it for off roading and the ground clearance you gain is ideal
