Hi
I have had two 460s so far, very good saw lots of grunt with 18" or 25"
Only problem I have found and this has happened again today is that it was working fine, then after a re-fuel it failed to oil!
Not sure if this a known issue or not but as I say this is the second time.
P.Hall
http://www.greentreeworks.co.uk
  • Replies 22
i would go for a 460 or 441 would not bother with anything smaller
441 and 460 with 20ich bars are my smallest saws i use other than a 200t
best alround saw i think u can buy having said that iv played with a 560 and they are one hell of a saw if ur think of running a 15-18 inch bar
560 is a smaller saw - not comparable IMO
But if it had a extra 10cc it would whoop some serious ms441 ass with ease! Used the 560xp several times,its a epic saw !
I've only had my 460 since January, but for the work I do with it (crosscutting timber for log production) its the DB's - don't know how I managed without it beforehand, TBH. I use 20 and 25 inch bars - no problems with performance or reliability to date, and not too bad on fuel.
I have one of these fine pieces of German Engineering. A little nose heavy with a 25in bar for my liking, but otherwise I can not find fault besides the tooless filler caps on all new Stihls( way too intricate for my ham fists). I love it besides these two minor blemishes and would buy it again tomorrow and the day after. Hope this helps.
I have a MS390 & XP266 both good saws - but they are like a 'push & go toy' compared to my MS460 (ok I fitted a twin port exhaust and retuned it = awesome bit of kit) with the retune it now uses more fuel so the fuel runs out before the oil.
I haven't used a ms441 to compare.
If most of your work is on the heavy side,then the 460 would be my recomendation.
I run 18" and 25" bars so best of both worlds
For felling and ringing up its perfect,and when snedding you dont need to stop walking.
Hope this helps.
Edited by oldwoodcutter
