telehandler with pto ?
turbull
I have no idea about the flow rates and pressures that handlers deliver so ignore me if this is way off the mark- how about fitting a hydraulic motor to your sawbench/splitter and making up an adaptor plate to hold the bench on the boom linkage? that way you could drop the sawbench off and use pallet forks etc pretty easily.
  • Replies 22
IMO of using our manitou with hydraulic attachments on there wouldn't be enough flow to produce enough power at a decent speed for a saw bench! Don't quote but i think there's only about 50-60litres/min at the front of the telehandler. Enough to run a good size ram, but hydraulic motors though we do use them on things do struggle to get enough power and speed!:001_rolleyes:
you will find that you will want to use the telehandler to handle the logs and the saw bench will get in the way and you do not need a pto for the spliter unless it a screw one. it will be cheeper to buy a old tractor and a telehandler, as you got more choose of handlers.
Most hydraulic splitters are PTO driven.
That's only because your average 35x or whatever doesn't have the flow rate to drive a big ram. A telehandler certainly would, so it's not likely to be a problem.
Personally, I'd get a good loader tractor. The money you'd spent on a half decent telehandler even without PTO would get you a cracking 120ish HP loader tractor.
Yes but the OP wants to be able to load an arctic, for that you need at least 14' reach hight, so that means a telehandler.
