same here gibbon, totally changes the way you see the tree aye. and making mistakes is a great way to learn, every so often i still find myself climbing ala dbrt style but on srt-getting there though and mapping the tree differently. love it
A few recent photos to add to the thread, crown cleaning Douglas firs.
The first few are actually from a 170 we did just the other day. Had to set up 2 climb-lines : the first set between 90-100 using the base tie, and the second to access and work the top 70. The other trees are a little shorter.
nice pics Reg, do you find that having the tether connected directly to your bridge ring inhibits your later movement?
It seems like it might when trying to limbwalk?
I was using the RW today on some titchy Willow lifts, using a RH hand ascender, anchored at the base, so easy!
What about reductions ?? Or long limb walks ? I would love to see a vid of a tree being target climbed on SRT that may convert me.
i agree with this i would love to see a video climbed without a throw line and working with the wrench
Matty, it's pretty much the same, you have just to make and get used to some slight changes. GandT using a throwline to access a tree SRT is usual however I am not a huge user of the throwline because most of the trees I climb do not warrant one but I have climbed, throwing (rope advance) then tying a running bowline climbing up and so on, I have also climbed the traditional way and then swapped to SRT at the top, whatever works, climbing has to be a little fun so trying different things can make it that way.
