, anyone know which models had points and when solid state ignition?
from IPL
112 Internal Points & External Coil (Cam on inside of flywheel not on crank)
113 External electronic Ignition unit (KTI)
114 Internal Electronic Trigger & External Coil
116 External electronic Ignition unit (KTI)
116si External electronic Ignition unit (Ducati)
117 Internal Points & Internal Coil ( Loose Cam)
119 Internal Trigger & internal Coil (KDT)
120 Internal Trigger & internal Coil (KDT)
120s Internal Electronic combined Ignition Unit (SEM)
120si External electronic Ignition unit (Ducati)
Not on the bench, more like part of the bench. I was becoming concerned about the risk to others imposed by the possibility of brushcutter heads, or parts of, flying around the workshop. So I came up with this simple solution.
Overkill?, maybe.
Overkill?, maybe.
[ATTACH]195655[/ATTACH]
[ATTACH]195656[/ATTACH]
:thumbup: good idea 👌
Got something similar for blasting the crud off chainsaws as it was making everything pretty dirty and now put it in a similar box that contains the crud - works pretty well:thumbup:
Overkill?, maybe.
Not overkill at all. A brogio head failure (I know - they're banned) would destroy that box. It'll slow the projectile but doubt it would stop it coming out...
Been working on a 350 Husqvarna, found a massive air leak around the upper crankcase where it joins the plastic bottom casing. A thin smear of liquid gasket still leaked so used a thicker layer and bingo, got a good seal in the end and then......found the impulse connector on the manifold was split:thumbdown:
Fitted a good second-hand manifold I had and got it sealed in the end.
All back together, ran perfectly and then went to put a bar on it and bingo......the side cover chain brake pivot pin was shagged....I love days like this, hours of work on a limited budget and just when you think it is done......:001_rolleyes::thumbdown:
Could be worse, it could have taken you 4 hrs to get from your place to Maldon. :cursing:
from IPL
Thanks for that
What's IPL?
