got a really big storm damaged beech to cut up and the stump is going to be in the way for builders that are coming to fix a retaining wall..so need to be moved.
Its a massive stump and i reckon it will weight 2 tons. Access in bad so no crane.
Any ideas?
  • Replies 55
Worth a bit of effort cleaning it up before starting - will save chains/teeth. If you (or the builders?) could get an excavator in to knock the soil off? Any way to get a pressure washer to it?
If you can get even a modest excavator in then it will break up the smaller stuff and drag the bigger stuff, which will cut down the grunt work and chain damage.
Alec
