Need your help here fellas.
Been asked to de-ivy a (small) cliff face, which I can do using a ground anchor in the garden at the top and abseiling down the face.
Problem is, my rope would be routed over a double skin brick wall.
What can I do to get round the problem?
MEWP access is not feasible here due to a variety of reasons.
Thanks
  • Replies 44
Could you fashion a H frame out of something, Maybe 3 scaffold bars or similar and let your rope run over the smooth metal? :confused1:
Just an idea
Sorry im wuite confused why is it a problem if its over a wall? and whats the cliff face got to do with it?
Edit: got the idea now.
Edited by Frankie Lawrence
understood the questoin
Could you drape some old lengths of carpet along the top of the wall, half down the face, half on top for your rope to rub safely over.
I was thinking that if you're going to abseil down a single line, then surely a couple of layers of something like carpet or matting could work, If you're going to use a "normal" climning system, anchor point to a H frame like Mozz said and then a little redirect pulley could do the trick. Only about £12 and handy to keep if you haven't got one.
Edited by Tommy_B
