I only done some amateur   laying.....
But how else would you"pleach" something that big? Think normally the bit left  is cut off lvl after
fbHvyG5040coOw0WtxZmRm2UICetrKLsDZzWa1Yi
Removing the heel or  spur as thet call it in this pic.
Edited by Stere
21 hours ago, nepia said:
Makes sense; a stump of hawthorn will regrow nicely.  But @Dorset Hedgelayer sliced the stump down the centre; why?
I'm just being thick, not argumentative (on this occasion).
Thanks
He'd have to. You wouldn't be able to form a tongue long enough to bend without going most of the way through the stump. It would never go down. You'd have to select the stems you wanted to lay and start your cut immediately behind them, just as you would a single stem. That means everything on the heal side has to be cut away.
I would say so looking at the pictures. I can't speak for Dorset Hedgelayer of course. He will no doubt be able to explain it better himself.
  • 5 weeks later...
1 hour ago, gary112 said:
E97D1E49-7AE1-4CB7-B7B0-491F86E25648.thumb.jpeg.6b066ff9981733c270828499345fe270.jpeggot a bigger one on the go at the minute,some of the pleachers are well over 20ft long
More of that skilled work Gary. Great to see quality work like that.
Thanks i,ll put another pic up when its finished
