On 07/12/2025 at 14:28, kram said:
My aim is great, power great, timing shite
if your aim and power are great then you should be set, no? Unless that shite timing means you’re not very accurate, in which case it sounds like your aim is, in fact, shite.
Listen, don’t speak.
On 04/12/2025 at 13:58, Joe Newton said:
Can't go wrong with Falteimer mate, mines outlasted every other one I've owned.
I've got one of the circular courant ones too which is decent as it doesn't fold up and twist your throwline.
I'm using Zing-it which has been my preferred line to date and just the cheap notch bags in a few different weights.
I also use those round Courant ones. The Stein cube folds itself if there is a puff of breeze in the next county, then it pushes a rod through the webbing after 10 minutes.
I've never had a favourite throwline. I hate them all!
Especially that "sushi' line. I bought that because I thought it would be twice as good because it's twice as expensive.
It's twice as hateful.
Had to check it out on Honeys, must be good if it's a game changer...
"The Samson Zing-It 1.75mm Throwline is a game-changer for professional arborists, ..."
but then it goes on
"easy to handle and maneuver, reducing fatigue during long hours of use. "
Something definitely wrong if you're at the throwline for hours, get a ladder instead. It's out of stock anyway so I'll have to make do with something else.
but then it goes on
Go with the thicker option if you don't want cauterised fingers every throw
Ive had all sorts of storage cubes over the years. Laterly two stein ones- as others have said the plastic rods poked through the corners after a year or so.
Ive gone back to using three gorilla tubs with an old strap. Also handy for using the top tub for transporting kit.
Cheap, multifunctional and lasts forever.
Unlike every other throwline storage device!
  • Thanks 2
Air launcher has arrived. I went for the significantly lighter alu tanked version which cost a bit more. IMG_20251218_133028.thumb.jpg.218b02c22dc91fc46aae6b182e5cddde.jpg
I'll get a plastic pipe to make the barrel tomorrow, thread is 1.5" bsp, plumbing shop will have it.
  • Confused 1
Pipe has been shortened but a 12oz does not fit well in 38mm pipe, it really wants to be the less common 42mm pipe.
Instead I'm 3d printing the tube.
Looking at a tree tomorrow and hopefully suitable to test it out.
On 19/12/2025 at 17:10, Stere said:
58273.jpg?v=1756734438
hmm?
