8 hours ago, Muddy42 said:
Sounds amazing! Id love to have one of those. Maybe when I downsize houses.
I think this fear of slumbering, or cold water cooling the boiler, low stove efficiency etc is way too narrow a frame of reference.  Your experience shows you can burn the stove hot and clean. Plus you are saving on heating oil/gas/electric.
It is good.  But don’t underestimate how much firewood it burns.  Probably getting on for a ton of properly dry firewood per month when it is cold.  So don’t even think about it unless you have the energy, space and time to process a whole lot of firewood.  If you have to buy it in you will save no money.
Here it is this evening.IMG_3719.thumb.jpeg.f699c8bf6d1291c7411c3285cf0ceadc.jpeg
Looks amazing.  I burn way more than that already. I mostly store in lengths and then have a few days with a log processor each summer.
Yes it's amazing how much wood even this little house gets through and no  backboiler.  I expect I get through 30kg of dry wood on a cold day.
I would like a small version of this:
to supplement my solar power in the winter.
Yes I've often wondered about CHP.  Are these things properly serviceable to an enthusiastic DIY-er?  One of things I like about simpler burners like ecoangus is you can take the whole thing apart - turbulators, fans, firebricks, pump etc.
I doubt it and I bet they cost a lot. Stirling engines are typically in hermetically sealed units, like freezer compressors, to prevent leakage of working gas.
The only DIY thing I would consider would need petrol, diesel, LPG or mains gas. A small water cooled engine  and in my case just running to charge a battery an hour or two a day in winter.
On 03/12/2025 at 10:25, GarethM said:
They aren't designed to be a poncy room feature, they're designed to burn hot and hard and store the heating efficiently out of sight.
That's partly why back boilers were stopped, it can't burn clean just ticking along slowly.
I’ll get through a wheelbarrow to a wheelbarrow and a half of wood per day, if we are here all day and it’s cold.
Obviously the wood is free, but we have to put the time in splitting and stacking etc.
plus the work of cleaning, sweeping, fetching the wood in the house.
Probably a reversible heat pump would make more sense, cleaner, can put it on a timer, can cool the house in summer as well as heat it in winter.
Do love the heat of a burner though, we’ll keep one till we leave this house in a few years.
