6 hours ago, HillyJohn said:
MSA 220 is same chassis as 200, more powerful motor; one thing to be aware of, especially with the MSA 300 is if you are doing repeated cutting, the battery will get too hot to charge immediately and needs to cool down first. Caught me by surprise when I used my MSA 200 for the first time, so for work use you need  lots of batteries!
Just now, gensetsteve said:
Does anyone know if the 220 motor definitely fits the 200 chassis and if so what sort of cost . I have one in bits so can measure it if needed
4 hours ago, gensetsteve said:
It looks like there are two different motors for the 200, they have different part numbers and covers than the 220 and the electronic module is different too. So even if the motor does fit you may not get any additional power due to the different control unit.
I've attached the parts diagram for the 200 showing the different motors and a completely different type of electronic module and an attachment for the 220
msa 200.pdf 220.pdf
