33 minutes ago, AHPP said:
I suspect it does have a bottom but will google what you mean. I’m trying to buy a property with no mains connections so I’ll have to learn about it at some point anyway.
Yes, probably, I’ll ask him more about it tomorrow.
Sounds good. My well is only 12ft deep and filling a couple of water butts will empty it but it generally refills in a day. I normally rely on rainwater as it's  a faff lifting the cap and dropping the submersible pump in.
From what I can gather it never was a traditional well but a hand pump shared between the two cottages. It looks like it was used to dump old bits of pipe in before it was capped and the mains was connected. If I were younger I would dredge it and should have done when I was.
If only there was someone with some spare IBC flasks in the south of England. You could bury/stack a few and run the pump as often as you liked to build up stock.
No need really, we have mains water and the sewerage rate is linked to our usage ( not intending to go down the composting toilet route) so I have to pay the standing charge and our daily average is 70ltr so no real cost savings are possible. I flush the loos mostly with greywater.
Morning all.
Glad to be seeing the physio this morning, then meeting the heizo this afternoon for a windblown Leylandii.
Looks like a good Monday!
Have a good one folks.
