What stihl strimmer to run mulching blade?
J@mesC
1 hour ago, Trailoftears said:
Just a different take on your needs, I've not used the mulching blades-they look pretty 'spitty' and nasty to me!Over the years I've generally gone with whatever the current stihl 40cc was,and recently 'downgraded' to the 240-c.Identical power output to the 361 but a weight saving of 1.5kg-not insignificant.But whatever m/c I'm using I find the brushcut knife 3-pointed blade a really good all rounder-nettles/docks/brambles up to your waist-even young samplings/gorse up to and over 1cm are dealt with easily.
That weight saving you refer to is the anti-vibe. Rather you than me.
Its true you are sacrificing 4 point vibe for 1 point vibe,also the gearhead is less robust too,also the handlebar mount point is not lifted as high as the 'proper' clearing saws too.But what swayed me-and I've used the last 3 gens of stihl cl.saws-is always using the forwardmost harness point to make the machine as forward heavy as poss (6 ft +),this clearing saw stihl gen Are truly,truly horribly back heavy-this you will know about when you take the strain and lift to clear waist high verges,banks-trust me-they are back-heavy pigs.Ironically,with the 240-cyou can slide the harness point along the shaft to EXACTLY where it suits each individual precisely.Not a huge fan of this generation of engine-its a badly balanced back-heavy lump.Tge old fs400 were far superior balance wise.I expect a change on any new versions of these saws.Also the shut lines on the engine areas/covers and cowls are the worst/biggest I've ever seen on Stihl high end cl.saws tbh.
As an afterthought too,with the 240-c you get to grease the bevel gear area with your own,hopefully premium grease.As far as Ive seen-the clearing saws are know sealed for life with no option to re-grease,I have heard many complaints (and heard) local authority operatives with worryingly whiny gearheads....
10 hours ago, Muddy42 said:
Battery or 4 stroke won't have enough umph for clearing or mulching with a blade.  For brambles and saplings, I'd want a fair amount of power, just seen you have bought the FS461 which is 45 cc, ideal.
I do it with mine, cut trees and gorse well beyond what the mulching blade is really meant for, I prefer the 3 prong mulchers :nurse:
They've gone back to having grease points on the new incarnations. As for local authorities having problems not being able to grease the heads, I haven't seen that it makes any difference. Most of the operatives probably wouldn't know what grease was, even if you smeared them in it.
  • Haha 3
Lol-I hear what your saying....
I looked long and hard at the fs 131 over the 240 c.Which is Much lighter with a (slightly)lower power output+much the same money.But what sold me on the fs 240-c is the almost astonishing throttle response.Hand on heart,its been by far the most responsive 2/ clearing saw/b.cutter machine from stihl its ever been my pleasure to use.Maybe the 4/ fs131 would/could be equally good.But I couldn't afford to drop £600+ just to find was it as good as a proven pro 2/commercial machine.
Just going back to the first post those blades are the Oregon ones , we had problems with them  on our fs460’s  we had the clutch housing break on 3 machines using those blades always seem to be going out of balance, since we have gone back to stihl blades never had any issues, IMO , with metal blades you want 360 or bigger , we have had more problems with the 460’s over the years than the 360 or 410 , maybe just me but had at least 3 or 4 pistons melt, having said that they get a lot of stick .
