Square tooth sharpening
Mick Dempsey
Hi Mick - is that .325 chain?
I spent 3 hours trying to square file 325 chain [it was a few years ago] but I'm not sure it's possible - the angle you have to hold the file means you hit the top of the chain tie straps or there is something that blocks it. I had same shape as you got.
It should look more like below - more right angled.
Cracking vid here - and mega expensive files here if you're still keen! But I think you need 3/8 or .404 to get a true result.
WWW.CHAINSAWBARS.CO.UK
Click here to go back to the chain sharpening tools menu
Hi Rob, thanks for chiming in.
It’s a 550 standard bar and chain.
On the larger (longer/less used) teeth it’s hard to fit this file between the raker and the tooth.
I know it’s not right, it’s not even the right file, but it really does cut fast.
Did the 560 the other day, impressive cutting from that as well.
I will look at the vid later, after the cup semi final.
Edited by Mick Dempsey
I’ll bring my own saws in on Monday Mick. 😂
9 hours ago, dan blocker said:
Are you creating a right angle sharp edge? If so the more you sharpen it you create a possible fracture line and break the top of the cutter off? Especially in hard wood. Just my small brain thinking out loud🙄
Yes, that will deffo happen as it moves back along the tooth.
I don’t think this has legs, just found it interesting that you can get a very acceptable chain without following the proscribed methods.
Once these chains are finished I’ll go back to conventional methods I think.
