Do you think the vibrations of single cylinder diesel is killing the battery?
I thought this was the 2nd battery, but looking back through old receipts it's actually the 3rd dead battery now on this machine since October 2016!
First 2 were cheapos, but this latest one was a Yuasa, and it has lasted 13 months.
Tested the charging voltage on the machine tonight and it is a nice steady 14.36v throughout the rev range, (which I would think is ideal?) so the regulator must be working?
This Yuasa battery was fine the other week, even when it was sub zero, but today it won't even turn over the warm engine, on the voltmeter you can watch the volts piddle away to nothing, it's like something has suddenly happened to it.
The battery is well secured, but the mounting, (which I made, so I would be to blame!) is mounted to the bottom of the engine mount, and being a single cylinder diesel, it obviously has a few vibrations
Is that a Kubota OC-95, as the charging circuit only puts out 12v 48w, so 4A.
I'm guessing it's just not enough to charge the battery after it's started, are there any electronics aswell?.
9 hours ago, woody paul said:
Has it stood out in the rain, I know someone how's tractor did the same turned out to be rain getting in or on battery and messing it up.
It lives in a shed normally, but does occasionally have to work in inclement weather :bath:
How often is the machine used? Batteries self discharge and gradually sulphate themselves up if you don't use for a few weeks, I used to get through a battery a year on the Spitfire until I bought one of the condition/charger units that you leave on all the time.
Yes oc95, only a small alternator, but the machine usually puts in a fair shift, often used for hours on end (at full revs).
This yuasa battery has gone straight from fine to fooked, not like a normal flat battery
If/when you replace it I'd consider buying one from Halfrauds.  Whilst they may be more expensive than some, they do at least honour their warranty - I have had two batteries replaced by them under warranty, one of which was almost three years old.
Is it running any electrical solenoids etc, not saying the battery isn't a Friday special but solenoids use a surprisingly large amount of current or maybe current leakage.
Out of interest what's it on machine wise.
