Has anyone ever tried milling greenheart with a circular hand saw? I have a lot of greenheart I want to mill into beams to build a house.
Thanks
N
Thanks
N
Not a chance in hell will you mill like that. If you have a large quantity to mill then get a chainsaw mill type setup Rob D from chainsaw bars does a starter kit.
Chainsawbars
Chainsaw mill
on a budget
Edited by topchippyles
Thanks
N
I’m home at min but back up in Lochmaddy from Thursday onwards ( weather and ferry permitting) and can-easy take a look, it’s a bastard to mill and the dust  is not good for you, is the timber off old piers etc ??. PM me as ive a decent 880 and Alaskan set up as well as the Trakmet mobile saw but that would be a bit of hassle to get over 😂 Shame as the stellite tipped blades do cope ok with it. .
  • Like 6
The Stellite tipped bands that you mention will no doubt be the best solution for milling this long since seasoned timber... but alternatively perhaps if milling with a chainsaw it would be an ideal opportunity to use Stihl Rapid Duro Tungsten Carbide chain.
From previous experience seasoned Greenheart is very hard on [ destructive ] any ordinary chain, cheers.
Cheers for the info, any idea on sharpening protocols with the tips and availability for an 880.
Never used them for milling but we had a few short chains for working on dirty stuff, very frustrating as the cut so slow in comparison to a standard chain.
The guys seldom brought them back but I did a few by replacing the cutting disc in the chain grinder with a diamond disc for saw sharpening, slow job and it didn't form the gullet.
1 hour ago, Muddy42 said:
This whole thread is a wind up, right?
Maybe I’m too trusting 🤷‍♂️That thought never crossed my mind. I know my big Makita circular will do most things and I’m sure Andy has a 300mm or bigger blade model which I guess could do the job 🤷‍♂️Who knows.
