Hum / vibration over winter... at wits end
This weekend I found time to record with a condenser mic. With the mic in the stand I didn't see much, but with the mic lightly touching the wall I am able to see a difference between when the hum was there in the morning, and later in the day when it's gone.
Orange line is power recorded for different frequencies when I could hear the hum, yellow line is same setup but later in the day when the hum was off. The blue line is a control with the mic off to see the line noise in the laptop and audio interface.
Looks like there are two things there, a tight frequency around 20.5 + harmonics up to 102.5 (5 x 20.5) and also some peaks at 47 and 49 Hz.
I suspect the thing around 30Hz is fridges and freezers as it appears in both conditions. I could try this with the electricity in the house off as recording on a laptop with a USB interface.
I think 20.5 is certainly in the ball park for resonant frequency of a pitched roof and I think mechanical resonance induces harmonics so that's still the best guess.
Will try a longer recording (this was based on 1 minute) to try to pin down the frequency as accurately as possible. Best I get from this (using a longer analysis window is 20.52Hz).
I found this:
WWW.RESEARCHGATE.NET
1830263070_Screenshot2022-11-06at14_34_44.thumb.png.cfa49d55fa8afd2f25a16e75cbe3d740.png
So crudely interpolating to say a height of 4.5m would give a 1st mode of 20.3Hz and second mode of 48.5Hz. So I'm thinking the stuff around 47/49 could be the 2nd mode of the roof.
Edited by thrope
I spent months imagining I was imagining hearing something weird while lying in bed, an odd intermittent humming. I finally figured out it is almost certainly the Leibherr freezer just on the other side of our downstairs bedroom wall. Resonating through the poured concrete floor that was cast hard up against the outside wall of the house( with no polystyrene expansion strip placed pre pour)
Doh!
I found this:
Is the thinking to identify the frequencies and fire back the same frequency out of phase to neutralise it?
Not thinking of any active correction, but first to identify what it is, and if it is the roof resonating I thought if I could shift the resonant frequency of the roof by adding weight maybe to some of the beams, then it might move away from whatever vibration is coming from the farm and reduce the effect.
Or construct a tuned mass damper like I linked in earlier post to target the 20.52Hz resonance. That's a mass and spring system tuned I think to have the same resonant frequency, but with a damper attached. Mostly they seem to be on a much larger scale though (bridges, skycrapers etc.)
Doh!
Some nights , lying in bed , I would be listening to what sounded like to me a big diesel engine ticking over . I would get up and open the window to listen , nothing . This happened quite frequently . It took me several months to realize that it was my pulse ! The blood pumping in my head near my ears . Bonkers innit ?
  • 1 month later...
  • 1 year later...
  • 7 months later...
Hi
I read your post and this sounds exactly like me. I started hearing the same last year in.my village in Norfolk. September to April is potato lighting time on farms. I identified my source as a potato dryer facility on a farm in the next village. Attached to the dryer is an air source generator. These are timed for 12 hours and ramped up overnight. I got environmental health involved and they were useless. I read your post and it was so my experience. I have purchased a snoozeband deluxe which I wear overnight. Brought from amazon. I listen to brown noise from a sleep app balance. This is free for the first year and then £66 thereafter. The app also has other sleep meditation programmes on it. It drives me mad and I am considering moving in the future. Other people in my village can hear it but not many. I too have sensitive hearing. I got my MP parish council and Environmental health on board. No one helped me. They said it does not meet statutory noise complaint! And the law does not take into account people with sensitive hearing!
I wonder did you have any luck with your noise/ vibration? I was told by the farmer who owned the dryer it was not a legal requirement to have a vibration assessment.
Thanks
Linda
