Tree planting wasted efforts......
Stere
When you get paid per tree they'll plant them anywhere, I did read an article that was atleast a little pragmatic and suggested they should have started around existing fringes of forest which would guarantee better success.
I'm not a eco type, but they do need to be a bit more selective in the schemes.
The Aral sea would be my first choice, literally an inland ocean has disappeared if solved would probably reduce the touted rising sea level and turn a desert back to farmland.
38 minutes ago, Stere said:
E360.YALE.EDU
High-profile initiatives to plant millions of trees are being touted by governments around the world as major...
Shame...
Lack of aftercare &  initial sensible scheme planning etc
Bit like most council/charity tree planting schemes in the UK.
Fixed that for ya...
There are so many ambitious targets to get more trees in the ground and rightfully so. It is all well and good government putting numbers out there, however it would appear that there has been little thought about how these targets are going to be achieved in the real world.
The issues that local councils and private businesses face are multifaceted, on one hand stock is an issue, many of the nurseries work well in advance and won’t have factored these large new targets into their plans. Staff as we know across the industry is a real problem, there is a genuine lack of staff across the board and whilst one may argue that planting is not as skilled as an 80ft takedown over targets you still need people who understand the job and are competent at undertaking the works. Coupled with this budgets are an issue, government want to plant more but the funding needs to be there. Yes there are various grants and subsidies, but are they really enough? Also these new trees will also need maintenance in the future, especially in the urban environment. Aftercare is also a real issue, many of the problems we see like in the article are the result of a lack of aftercare. It’s all well and good planting trees but if you do not invest in a three year aftercare programme you may as well poor the money down the drain.
Around the world you can argue planting trees can be beneficial to the environment of those countries, think reversing desertification that sort of thing, the UK and most northern counties not so much as we have large amounts of forest and managed and productive farmland.
What is the point of planting trees on valuable arable land ?. What is your goal, carbon dioxide reduction at the expense of growing it in the 3rd world?.
We do have large amount of woodland in this country, however in many locations that is steadily decreasing. Not all arable type land is used for food and crop production, I’m thinking of land that is used for things like shoots, set aside etc. This land could have trees planted upon it. For land that is used for crops maybe sections of it could be used for trees and shelter belts as opposed to planting full on woodlands. This approach could benefit the land in many ways including adding biodiversity and wildlife to the area.
The ICF has an event coming up which looks at integrating trees into farmland, it would be interesting to see what the ideas on this are.
WWW.CHARTEREDFORESTERS.ORG
This ground-breaking hybrid conference looks at how we can integrate trees into the farmed landscape and build...
