I always wondered how they get away with drug testing like that.
You could go to the Netherlands or Spain, where it's perfectly legal, but fail a drug test here after, yet you've done nothing wrong.
You can't be turning up for work with it still in your system, ten days after the event seems a bit harsh mind. Never mind, something else will turn up.
Edited by eggsarascal
But there's a difference between traces in your system and being intoxicated. As you said, 10 days later, but you failed the test. No way you were still under the influence at that point.
Apparently this is one reason that hard drugs are such a problem in prisons; they're preferred because the traces disappear from your system much quicker. Whereas traces of cannabis linger around long after the intoxication has finished.
Rules is rules, and I signed on the line. What don't speak don't lie, it's a positive test.IMG_2320.thumb.JPG.7100b53a10933a2b2dd226be1f27d370.JPG
If the company has a 'no drugs policy' and most do. Harsh, I agree
Edited by Con
I’ll stick to the crack then
4 days for that, up to 28 days for a bit of weed, utter shite.
I hope you get something sorted soon Eggs.
