Hence why I said it would be the only reason to go to all that work. [emoji849]
It would be a lot of work and expensive for me to get in the car, drive to home bargains (other cheapo shops are also available) and spend money on firefighters when I have everything available to make them at home for nothing other than my time to put a shovel of sawdust into a bucket, and mix it into some melted wax.
I’m not sure why you think it’s a lot of work? it seriously isn’t, it takes a couple of minutes to make 50 firelighters.
It would probably cost me a fiver in fuel to get to and from home bargains with the current fuel prices and I would have used an hour of my time - when I take all that into account pack of 50p firelighters doesn’t sound cheap to me.
Oh and I’d have an extra bucket of sawdust to dispose of too [emoji23]
You must spend a fortune when you drive into town solely for Milk. Then the next day for Bread. Then the next day for butter……..
Learn something new every day. I didn’t realise home bargains also sold milk, bread and butter, might have to start doing my weekly shop there
Every days a school day.
I'm a weirdo, I occasionally collect a few bulk bags of sawdust from the sawmill, throw some in the chicken run, mix a bit in with the woodchip, put it down as a path in the polytunnel, tried it as a mulch, etc, it's all free organic matter of some sort and it will rot down into the soil.
Also built a compost toilet last year, that uses sawdust, but only a tiny amount really!!
For home users who generate just a small amount of saw dust (like me) I have thought about this and looked into it.  Pellets from a machine are financially out of the question.  I really can't see the mess of mixing with shredded paper in water, then compressing and drying is going to be worth the hassle.  I tried mixing with candle wax last year and it worked but was a bit messy (quite possibly would be easier with a bit of practice and might do it again).
I mostly just shovel it into a large flexi bucket and put handfuls on the fire to aid lighting.  No messing about with it, just use it as is (once it has dried a bit).  Putting it in some kind of box you can put on the fire is clearly also an option (easier to store and cleaner) but TBH as I can just use it as is I don't see the point in messing around trying to turn it into some other product.
Coming back to this again,
I've seen and made the sawdust burners (last years experiments), and they work well, barrel of some sort, even a bean tin sort of works (for the kids!), a hole down the middle, and off it goes (got in trouble for this one when I tried that in the garage and it still smelt of smoke in the morning).
Wax, or used oil, yes, seen that and I reckon that would all work nicely. Been making lard/seed bird feeders with The Boys this week, wonder if melted lard would work too, then decide which is cheapest.
Back to what I was doing this week, dried coffee grounds are no good, crumbles, so now trying the same with wet coffee grounds see if a bit of water helps (thinking back to coffee shops having to smack the coffee holder to get the pressed coffee out after making a brew, though this might be a factor of it being heated up with the hot water / steam). Wet coffee went in last night, 24 hours later - tonight - will see how it goes.
If you are trying to form briquets you need a binder of some sort.  Plenty out there on the web about it, once you wade through all the wet paper solutions.  You can do it with wood but it takes a lot of heat to do it, which is what the pellet machines do.  Rather than experimenting randomly I'd do some focussed Googling/reading.
