5 hours ago, john87 said:
The fan broke up and despite the housing being a welded construction of about 10mm thick steel, that was just torn open like a papaer bag.. The one piece that burst out of there, cut completely through a steel beam about a foot deep in the roof of the place, then made a large hole in a brick wall and shot off god knows where.
Which is why one should never walk past the chute of a working chipper. I've seen the aftermath and the pieces of disc picked out of the back of the truck.
Yes, as i say, i have never used one before, and when i started mine i was amazed at the velocity and volume of the air that came out the chute, never mind the chips.. From a quick calculation the periphery of the disc would be doing about 130 MPH so if it all fell to bits shrapnel would fly in a big way..
On a different subject, i have to cut down a load of bamboo.. I would imagine that i would have to be an idiot to put this in the chipper or am i being too fussy??
john..
A sharp chipper cuts it and a less sharp one breaks it up, just watch out for blockages, one piece at a time until you trust the chipper.
Hmm, Mine has a brand new blade now and i checked the anvil too and that has a nice sharp square corner so all is well, but the bamboo is so hard i might give it a miss and burn the stuff.. How do chippers cope with leylandi trees.. Will it munch them up happily?? I have a huge amount of laurel to do too but i cannot see a problem with them..
john..
john..
The tree wood itself ( Lelandii ) is no problem . The green brashy stuff can sometimes get stuck under the roller spigots particularly if the machine has not been maintained properly .
john..
Dry leylandii yes,  wet maybe not so well. K
john..
Bamboo's no problem to sharp blades and correct anvil gap.  I have a wee chipper and chip the stuff regularly; never had a problem with it.
Laurel's fine too; I love the smell.  That cyanide... oh yeah!
The bamboo is about 1/2" diameter i suppose. You have a job to cut it with a machete.. Hopefully my brushcutter with a steel blade will do it though. [I hope] This blade here i have..
Do you feed the bamboo in a bit at a time or just chuck armfulls in??
john..
