Is it exhaust smoke, or smoke from oil caked onto the barrel fins/exhaust getting hot?, can be bad when chogging down due to long cuts.
I have wondered this too….it is seriously dirty in there. I’ll try and pin point the source next time…
Cleaning all that shit off seems impossible.
Or , or like my mate did . filled it with diesel , The " keep on truckin' " and Yorky bar jokes lasted a while [emoji16]
One groundie once got my oil and fuel the wrong way round on the echo 2511. That really did stink for some time.
I’ve seen a cooked cylinder on a 200 because of oil and sawdust blocking up the cooling fins.
its worth the investment of the time to clean it 😉
I did that on my Chinese top handle 🤕 I couldn't even start it till I'd cleaned the carb twice it had glued the metering diaphragm solid.
I found that when I put some oil in the fuel tank of our Echo 2511 (realised before starting it, iirc) it took a large amount of cranking over to clear it with fuel, compared to the same event on a 201T. And no, this is not a weekly occurrence, just cos I am honest enough to admit to having done it twice in a century!
Cleaning chainsaws, that would be a first for most!!!
Thought that was a service you provided......
I blow mine out with the compressor when it looks dusty, a little and often is always easier than trying to get the baked on stuff off especially if you've been cutting pine or similar.
