200t starting to smoke
stewmo
As the title says, my good old  200t is definitely starting to smoke a little, particularly chogging, don't know if its the summer heat or not, but just wondering what its a sign of? What's wearing out finally?!!
Have not changed any variables such as 2 stroke oil recently
cheers
2 minutes ago, htb said:
Is it exhaust smoke, or smoke from oil caked onto the barrel fins/exhaust getting hot?, can be bad when chogging down due to long cuts.
Or , or like my mate did . filled it with diesel , The " keep on truckin' " and Yorky bar jokes lasted a while 😁
Idiot i used to work with filled his old Scirocco up with petrol/diesel mix we drained out of a customer's car. In his bizarre logic the mix would "clean the carburettor".
It didn't, and he ended up rebuilding the carb as the diesel ate all the seals or something.
  • Sad 1
