  • 0
Best Time to Fell a Tree
AlwaysLearning
Question
My mum has a tree that really needs to go.
It is a decidious cherry plum, perhaps 8m to 10m tall, 2m from her house and perhaps 3m from her neighbour's. The trunk is about 45cm diameter and the soil is a free draining sandy soil. The branches are rubbing on the tiles so I'm guessing it's just a case of when they'll do damage to the roof rather than if. Also, power is supplied to the house via an overhead cable anchored to the chimney stack. If the tree isn't already tickling that cable, it will do soon.
My question is is there a best time of the year for it to be removed?
  • 0
32 minutes ago, AlwaysLearning said:
Well I'd rather avoid killing off any young birds that may be nesting in the tree
Yeh, need to check to see if any birds nesting otherwise no issue in felling any time of the year - most birds will also have finished nesting by the end of July.
  • 0
As it's not a large tree you will probably be able to see any nests present from the ground. I think the Arboricultural Assoc. say bird nesting season in England finishes around end of August dependant on weather.
You might also like to check with the Local Authority to see if the tree has any legal protection before doing any work.
  • 0
We have found chicks in the nest in late September on more than one occasion. These were blackbirds about 7ft above ground in a conifer hedge.
  • 0
Unless you are a pigeon  then there is a bout 2 or 3 days end of Jan when they are not at it !.
