On 04/07/2021 at 17:11, Jack.P said:
Stihl 261 is a good all rounder upto 18’’ .i didn’t score the 391 highly it was underpowered for the weight
It is, dunno why i just bought 550xpg 😣  anyway, anything without full wrap handles is a pussy saw. K
donttellthewifedonttellthewifedonttellthewifedonttel....... oh poo...she's not colour blind.
Listed as amazon as the seller not somewhere abroad yet it did one of those price variations i put down to exchange rate changes....and dropped to £269.51 😲😲😲
I hit buy.  I mean, that is an astoundingly cheap price.  5 left lads....go on....make me see I'm no weaker than most men!
I now have a nicely looked after ms180 going spare, with some spare chains.
I notice its got a pussycat. I assume I should remove that, add about an 8mm-10mm hole to the muffler, pop the flywheel and shave 0.25mm off the key, refit, pop the limitters and then twiddle the high screw out a bit?
I've never shaved a flywheel - guess that's up to you. but certainly worth getting the cat out. From memory once that's happened the outlet is plenty big enough
Done the cat on mine and it does make a noticable difference,but went well before anyway
Good to hear.  How much did you open it after gutting?
Did you bother with timing advance too?  They should give a little more.
Oh and does the carb have limiters as stock?
Didn,t do timing and carb doesn,t have limiters,but maybe Andrew(Shavey) had sorted that because he had run it up before i had it,just tweaked screws a bit and she was flying
No I've never done that on a standard saw but wes went the whole hog on my makita
Including lightening the flywheel and porting
And it's a fantastic runner
