Usually its a surface grinder with a jig to hold the blades at correct angles, used one at one company - bloody old thing with hand feed, a tedious job at best. Hard white grit stones.  K
There is a vast difference in a set that has been sharpened in a chemical bath and balanced than a set that’s been slung on a bench grinder jig... I know what I’d rather have in my machine and a decent sharpener is going to set you back 3k.
Tinny wolf gets what it’s given but I have three sets for the schliesing as you have to adjust the clearance for the anvil so it’s easier to buy 3 sets and reset every 3 sharpens.
Interesting stuff. I imagine they just use a planer blade sharpener, they usually have a 600mm bed so you can run both at the same time.
Like you say, not worth it financially.
Do ten or so and yr definately ready to pay some other bugger to do it. K
Surface grinder - there is about a ton and a half weight difference. No one should use a bench grinder to sharpen chipper knives  ( at least not my knives  ! ) K
Also a decent surface grinder will have slurry ( cutting fluid ) spraying on the wheel . No over heating .
