5 hours ago, stewmo said:
I was thinking about this blade sharpening every 20 hours or so..... Isn't it possible you could clock that up in a busy week? Or am I missing something about 'hours'?
And therefore 300 hours could make a machine, even at 10 hours a week, just 6 months old?
Thanks
Depends on the machine, but twenty hours of chipping over a week of domestic work takes some doing. Some jobs you'll do well if you clock up an hour a day.
Indeed,  physical blade contact with wood for 20 hours is quite a long period of time.
When your blade edge and angle is also your "feed roller" its important to keep them tip top. A flat knife on a hydraulic feed roller machine will still turn cord wood into some sort of chip if they're blunt as a spoon.
On a hydraulic feed roller chipper a full time domestic tree surgeon will usually rack up between 150 and 200 hours a year. Its surprising the lack of hours a chipper does. We hire them out and they'll often come back with 1 additional hour on.
Rail contractors maybe will do 400, we have a 2019 SafeTrak in for repair / service at the moment and that has 351 hours. I would class that as pretty high hours for a machine less than a year old.
Interesting stuff. Thanks it seems hard to believe but can’t argue with your experience.
Anyway so say 1hr a day, 5 days a week, that’s going to be a sharpen every 4-6 weeks. I’m just trying to get a gauge that’s all, cheers
I have two 150mm hydraulic chippers just come back in off a lease. One is 2 years old and has 201 hours, the other is 2.5 years old and 340 hours.
I don't know anyone who uses a CS100 or a similar gravity chipper 5 days a week for a month?  If they have that much small chipper work then fair play!
I'll have to check but I'm pretty sure that a GreenMech ArbTrak200 in Poland did 3000 hours in a year!
That's good going?
Some machines need another hours meter on them- the how much time it's saved you hours meter!
Like my loader, hasn't done 3 hours a month, saved me days!
On a slightly different note....setting the anvil. Do people generally have the anvil set to the maximum gap? I'm presuming this will give maximum pull on the brash too....
cheers
cheers
On a CS100?  Nope, 1mm.
