7 minutes ago, Will C said:
Remember a new silky will always want to draw blood, give them respect
..... I wasnt gonna tell her thatΒ  (Β  Β  'stumpy n stubby' sounds good)Β  πŸ˜‰Β  K
I definitely wouldn't get the Sugoi! Great saw but, to big for most stuff. The Zubat is a good all rounder, it's better for usingΒ at a reach or above the head and also reaching down below the feet. When on the ground I found it better to use a straight blade as I didn't need the hook to assist cuttingΒ
What is a fair price to pay for one of these Gand ? Amazon want Β£60 πŸ™‚Β
WWW.GUSTHARTS.COM
Browse our Silky range of Hand Saws
HONEYBROS.COM
Silky from Honey Brothers. The largest equipment specialist in the tree care industry.
always good service from both of these guys and they don’t charge extra postage to the island like frjones do.
Β
i prefer the Gomtaro over the zubat but nowt wrong with either
On 31/12/2020 at 14:28, SamanthaSunny said:
These Chainsaw trousers are made for women so hopefully will be up to the job and they are class C so fine for Lantra courses. Does anyone else wear Arbortec ? πŸ™‚
None of themΒ not really stretchy as none of the blocking is, its only the outer. the blocking material is still a gentsΒ cut, as that's the CE standard(unless they've written a new standard them self, which other manufactures can copy!)Β
  • Sad 1
That’s mis selling surely ☹️ Should I cancel and order the same as the lady on the video ?Β
Absolutely, but they won't magically transform you into a Stihl ambassador overnight :biggrin:.
Can you try them on and ship them back if you're not happy in these covid times?
Β
I think Honey bros are probably the best place to buy the Silky too, I haven't used a Zubat, but they seem to be a good saw. I use an Ibuki, less likely to break and can be filed.
Β
Lots of threads on here about 'which Silky,' they all seem to be little vampires. Bahco is a good, cheaper alternative too, I use one for high pruning.Β
  • Β
Arbtalk.co.uk is a hub for the arboriculture industry in the UK. Β
If you're just starting out and you need business, equipment, tech or training support you're in the right place. Β If you've done it, made it, got a van load of oily t-shirts and have decided to give something back by sharing your knowledge or wisdom,Β Β then you're welcome too.
Γ—
Γ—
