5 minutes ago, Melton Martin said:
Hi All,
thanks for your replies..Also have tried pulling harder, again no joy,
You will go blind !
3 hours ago, Melton Martin said:
Hi All,
I have tried more than the recommended 3 wraps around the capstan drum- not much changes.Also have tried pulling harder, again no joy,
best phone Sion @Treadlight Forestry then
BTW what rope are you using?
I am using braid on braid 10mm polyester rope as recommended by the manufacturer. Yes, I pulling(!) hard to get the friction on the drum, and I have been using the recommended number of turns, which is 3 to 4 wraps around the drum - However, I will try more, but with too many turns around the drum I find the rope jams under itself then locks.......
I'll give it another go tomorrow and let you know the result......
On 02/07/2020 at 14:19, Archie Fenton said:
I know it sounds silly but you need to pull the rope through with it ! It won’t do it on its own
I had that problem with self- mixing two stroke oil ...... left it on bench overnight next to petrol , still hadn't happened by next day   :(  K
I'm using 13mm  as supplied with the winch (Ultra High Molecular weight Polyethylene)  .i'm unsure if the sheath is the same fibre as the core. I probably haven't reached the winch 2 tonne limit yet, perhaps I'll see if I can stall it when next out.
If its an offset capstan,.which some of them are , it could make a difference having it on overwrap on retrieve rather than underwrap .
1 hour ago, Haironyourchest said:
There's a spray-on product for slipping v- belts that increases grip. Maybe try that on the rope?
Belt dressing. I've used it with some success on flat belts.
