My father had to have his thumb stitched on again using a saw bench similar to that.
Could have been worse, my father told me a story of a bloke using one who had the bright idea to convert it from belt drive to PTO.
The higher revs caused the blade to overheat, split a chunk off and (owing to higher centripetal force) sent it into his skull.
Thank you for all the replies . I have been using poplar this week for kindling 4-6 inch stems. I am thinking now the smaller stems have smaller branches and therefore small knots . Also younger stems are softer and easier to split . Maybe a decent wood processor would be good to cut up to 12 in ch stems
1 hour ago, Harris2020 said:
ma
Makita 5402NA 16-5/16-Inch Circular Saw is the best option i ever used. It has more efficiency to work!!
Another Harris! Nice. :)
I'm planning on buying a 5402NA for (hobby) Timber Framing if I can ever find a used one over here, most likely a makita 5143r.
Edited by trigger_andy
Yeah that is good one as well makita 5143r.
anybody still use  theese  type of bench saws have one similar looks lethal never used it.
Yep they are lethal ! Too many horror story’s!
26 minutes ago, daveatdave said:
is this the size you are after not that I recommend this one
That one would be over a hundred years old i should think. Health and safety would have a field day
that why I did not recommend it just trying to find out what size is requierd
