Hi guys,
I have a ms391 (2012) that I use for the bigger bits of fire wood which is Mainly ash up to 30". Would like to up grade to a newer saw which will be used for ringing up. Welcome your advice ?
So the MS 391 is about 65cc ?  Do you want to replace it ? or keep it and get a bigger saw as well ?  as above a 372xp is a cracking saw .
50 minutes ago, Oakbeam said:
Hi guys,
New or second hand?
Thanks for the advice guys I am kind of keen to stick with sthil but will keep the options open.... I think slightly bigger would be good !! Thought about a 462 but would that be a bit to "sporty"
372, no electronic carb to go wrong, they are good solid saws. 365xt can easily be converted to a 372xt.
Can run your stihl bars on 372 etc with a converter from chainsawbars.co.uk.
Its not as sporty as a 462 or 500i, but its for ringing up firewood after all, not felling on piece rate.
Was offered a good s/h 372 about a month ago for £200, should have bought it really, was well looked after with little use.
