45 minutes ago, Stubby said:
The second lock down looks like a Water Board lock . If it is give them a call .
It is a Abloy lock used by the water authority, smack it with a hammer and it'll fall apart. Failing that get an Abloy pick.
1 hour ago, Bolt said:
Those locks could be made of cheese, but that wouldn’t help him get out!!
Yep, just spotted that.....now that you mention it...
47 minutes ago, Stubby said:
Why does he not just undo it and let himself out then ?
Have another look at the picture, the bottom 3 locks aren’t doing anything. Only the top two are making a loop
1 hour ago, petercb said:
Only the top two look to be doing anything presumably his is one of the lower ones.
So why would he put his  lock ( if indeed one of them is his ) out of the loop ?
I would guess that he went in (via his lock which I'm guessing is one of the bottom 3, hence his predicament) someone came in (or out or in and out!)  after (through their lock) and has "tightened" the loop when re-connecting their lock, effectively rendering the three lowest locks unless for being able to come in or out.
Following?
Following?
Had that happen a few times when working on phone mast sites. Chainsaw files can be handy or a level 6 key(bolt croppers). All superseded by cordless grinders.
Top 3.
6 locks in the picture as I see it.
