15 minutes ago, htb said:
It's railway job you wouldn't expect it to be done right, only at vast expense.
I find that astonishingly cynical. And as  Rail engineer I will point out the correct hammer was used as per method statement and Coss instruction ( just weren't heavy enuff :p) k
But which end of the correct hammer was used?
Having spent 32 years in a Local Authority, I quickly larned that such arcane knowledge was somewhat  more esoteric than I  had foolishly presumed.
P.S.
I was pleased to see that Monsanto had thought to clearly specify that the plug was to be inserted smaller diameter end first.
Edited by difflock
42 minutes ago, EdwardC said:
Like this?
You see? Clearly yr confused with biros endus fungi. Easily mistaken fr eco plugging but quite harmless ? k
