BT, well their contractors, recently replaced a pole on my property. They just pulled the old one out in a few moments. The old pole was condemned and needed replacing within 6 months, 5 years later...
Anyway, getting hold of anyone to talk about the pole wasn't easy. I gather if it's actually dangerous BT Open Reach will come out within 7 days.
As for the cost, I would have thought removal would have been part of the cost of re-routing.
3 hours ago, skyhuck said:
Cut off at ground level and then stump grind to required depth.
Cut into lengths, makes excellent gate posts.
Yes I thought this.... good couple of 8’ poles out of it.
cheers
BT have said that the pole is their property and part of their infrastructure  and would need a engineer to come out to say if it is now not needed and that it is only openreach that can remove the pole....
Saved yourself a big fine there perhaps.
Could well have done.... I can tell when things aren't just right. Good to ask questions and research things before hand :)
I cut one down yrs back thinking I didn't need a phone line no more, what with mobiles an all..  then wanted internet and they came out seen the missing pole and wanted 800 quid for replacing it...
most expensive firewood I ever used...
Ha!!! You fucking clown!!! ? and you deserve to be poked at for that one!!! ???
I did explain that it was in a field that once belonged to the gypsies but they didn't buy it..   800quid or no internet..   fkrs...  took me six months before I could bring myself to pay it...
Oh and I don't imagine all poles have some cross member at the base, maybe only those on very loose ground, sand for instance..  I should imagine choppin em off and farm jacking the stump out would work fine ordinarily..
