Avoid cutting as highly carcinogenic sawdust.
Winch or crane jobby.
Are you sure? It’s more of a sensitizer for lung complaints than most woods but is it more carcinogenic than average?
I've never tested it personally, but i know I guy in Brighton who sells the old pilings(green heart and Purple Heart). He warned me I'd need a full suit and decent respirator if cutting or sanding.
it's fine for most people mate.
i've cut turned and sanded more than most in this country including greenheart and purpleheart and still the only timber i've had trouble with is the airborne dust of Iroko.
  • 3 weeks later...
I would have thought blasting out the silt/mud around the pile with high pressure hose’s would be the quickest, easiest, safest and cheapest option ! If you could get down a good way. Timber scissor tongs and a good winch would do the rest, you’d then be gripping sound solid wood.
https://www.google.co.uk/search?q=boris+johnson’s+water+cannon&prmd=sinv&source=lnms&tbm=isch&sa=X&ved=2ahUKEwiNiNaTr6_gAhWisXEKHatDDBIQ_AUoAnoECAwQAg&biw=320&bih=438#imgrc=oMEPN0SWGXnzGM:
Edited by Mark2
Iroko, was the wood that triggered the allergies of a lifetime old-school joiner that I knew and worked with at the time he was afflicted, he was perplexed how it happened after a lifetime of working with Iroko, in the days before dust masks or LEV.
Edited by difflock
Good to have input but why the political link to a brexit issue ie the opportunity to knock a boris decision. As it happens getting rid of the material at the base of the pile would be standard practice. Actually I should not be even responding to this as if you wanted to drag politics into the conversation there are other ongoing posts on this forum covering such items.
It was just a harmless bit of humour I added as an edit,
demonsrating the power of a water jet. Any political connection is a product of your imagination. Good luck
