3 hours ago, Stihl123 said:
brilliant, thank you. i'll get some on order and give that a go 👍
You can sort the set yourself, Stephen Cull will give good advice regards thst sort of thing.
thanks, i tried to call him this morning but believe he is away at the mo
On 04/08/2023 at 07:38, Stihl123 said:
i put it together myself, all the laser stuff came to just under £100, not bad at all
let me know if you want to know where and what i got
Yes! Yes please!
10 hours ago, Stihl123 said:
not many at all as only just got it.
i did adjust the throttle a little as it has stretched a couple of mm
i'll clean the clutch out and see if i can see anything going on in there
defo is pretty wet timber
they are Ripper37 blades, which i believe are 10 degrees
thank you
Ripper 37s will most likely be a general purpose 7 degrees.
When cutting softwood, run 50% arctic grade windscreen washer fluid in the coolant tank. Cheaply available in packs of 4x5 litre cans from your local motor factors. It'll make a big difference- your problem sounds like resin build up.
Thanks
Everyone seems to say something different! I've been told to use only water, some say add a bit if washing up liquid which is what I've been doing
Thought the screen wash was only necessary in winter 🤔
8 hours ago, Stihl123 said:
Thanks
I definitely don’t get good results using just water, my own preference is RTF tar remover type stuff mixed quite strongly with water.
ok thanks, think i'll have to do some testing to see what works best
On 08/08/2023 at 21:44, Stihl123 said:
On the sawmill, cutting some softwood and the blade seemed to be jamming in the log then riding the clutch, resulting in the clutch getting very hot.
Thought blade was done so swapped it out, but still doing it.
Did couple of cherry logs the other day, absolutely fine. They were down about 4 yrs before I milled.
The softwood has been down about 8 months
Any ideas please
You say the blade was a ripper 37 (same as I use) but was it new or sharpened?  If the latter then I would question how well the blade is sharpened.  I have found that very few people sharpen them properly, including saw doctors.
