10 minutes ago, Bob_z_l said:
@AJStrees  Do you use the ladder on every pass?  To ensure its flat and even in and out?
Interested as I only use it first pass.
Bob
Yep. Much easier with the ladder on each cut I find. Especially when coming off at the end.
Do you screw it down to a cut surface?
Yes keeps it all straight, etc... I prefer doing it that way personally. Have tried without and find the mill has more friction on the wood surface than the metal on metal. So have done it like that for the last 3 years to a good result. Yes some small holes in the wood, but that's of no consequence really as they close up somewhat and there are all sorts of imperfections in timber anyway. 👍
If you don't screw the ladder down, I assume the mill slides on the ladder and the ladder sticks to the wood?
If you don’t screw the ladder down there  will be a lot more vibration I would say. Also don’t know if the ladder would stay where you want it. 👍
