On 20/04/2021 at 21:36, Wonky said:
 I was busy milling this today, I got more to do tomorrow 🙄
Wot.. The whole forest  😉 k
Some big 4ft diameter burr sweet chestnut from a fellow arbtalker that i purchased a while back.
Cocked one board up and another split on an old union. Useable with some modification!
  • Like 8
 Nah,, just needed 16 sq mts,  measured at the small end 😜 I ended up roughly milling 20 sq mts 👍
you know, best be safe and have to much an all that. 😉
edit I managed to set the ladder and cut the tops off 8 logs, then mill 5sq mts the first day. the second day I milled 15 sq mts
Edited by Wonky
Added after the edit
Saw looks pretty old what model stihl is it ?
070, non AV.
I've an 070av and an 090av that I don't use for milling anymore, not that I ever used the 90 much anyway.
070, non AV.
Why would you not use the 90 for Milling? I thought they where the Dogs danglies back in the day?
7 minutes ago, Big Beech said:
070, non AV.
1968 according to google the first ones came out 👴 About £100 which would have bought you a cow
Edited by topchippyles
