11 hours ago, Alycidon said:
The original Morso boards are vermiculite, sold a set for a Squirrel today.
A
They must have changed then, my squirrel has fire clay...it's about 10 years old.
I'm still on the originals, although the two side ones have a crack they still do the job........I see on ebay I can get a full set of clay bricks for £37 or vermiculite replacements for £31.....it would seem that the clay ones are a better buy bearing in mind the difference in service life quoted buy others.
4 hours ago, richardwale said:
I buy the vermiculite boards of the Internet and use the old ones as a rough template. Very simple to cut and fit.
I  made drawings with dimensions  for mine . Filed them away . Get them out when I need them to order new .
Edited by Stubby
Can I ask where you guys get your vermiculite board?   Just a quick check suggested it wouldn't be a big saving over buying ready made bricks, unless maybe getting a really big sheet.  But if I only need a set of bricks every 10 years or so that doesn't make much sense.
On 20/11/2018 at 11:45, woodrascal said:
There's lots of teams doing them on Ebay. I buy the big sheets (I've got six stoves...) but you can get any size you need.
Here's a link to one supplier Vermiculite Fireboard
Thanks.  I can't make sense of that particular supplier who doesn't seem to list standard sizes.  Looking at others I found what I suspected, there's no saving in buying a sheet big enough for one set, but worthwhile if I want to make two sets.   I also need to check our other stove (Esse 100), maybe a sheet big enough to make a set for each stove would be economical.
