Waterproof alternative to plywood
Steve Bullman
5 hours ago, Woodworks said:
Steve what shapes are trying to create? Would be easier to guide you if we had a better idea of whats required
basically some sort of box shape with probably 3 compartments in.  That would be the rabbits living space, with pipes leading in.  Then will just be piling a mound of top soil over the whole lot.
Phenolic ply?
Offcuts of twin wall drainage pipe? Could use some big diameter 600 or 750mm vertically for the centre.with holes cut to poke 225mm in for the runs.
Thick hygieneclad plastic sheets lied and with 90° shelf supports to help hold it together?
