14 hours ago, westphalian said:
turned oil to max, will mill on sunday
You might also try engineering cutting oil, it's a water soluble oil for milling and sawing steel. Get a litre from yr friendly  engineering works, mix it to a gallon, with water n use that. The water content will cool the bar way better -but it does make yr clothes stink ! K
I hate the stink of slurry .
At what stage is the chain snapping? New, half used, or near the end?
[emoji106]
Half used. Always start with sharp chain. The chain on the bar hadn’t snapped I’d just be sawing up a load of pine bark planks
  • 1 month later...
well another snapped despite on full oil.
been googling.
so is lo pro not suitable for the power of the ms661?
is the few mm a lo pro saves worth it? (that was from a post from Rob on here several years ago)
do i need a specific lo pro sprocket?
i have now ran out of tie straps to repair the chains so i'm gonna have to do something
I think, if it’s not a 3/8 lopro sprocket, that’s the problem with the chain breaking.
3/8 and 3/8 lopro May look the same but they work/behave differently.  From what I’ve gleaned around the web, the lopro is a slightly bigger sprocket, and some where in USA I read that some guys were turning down 404 sprockets to fit the lopro.
I’ve also read that using the wrong sprocket is like using a very worn sprocket.
I cant remember what threads they were.
also I’m guessing you got the right bar with the tip sprocket is 3/8 lopro not a std 3/8 ?  If it is wrong then it will sit to high on the tip
