The pleasure in cutting standing Sitka Spruce
difflock
Mayonnaise is also really good. Don't use garlic or chilli flavour!.
Lidls or aldi is just fine, Hellmans is snobbish.
Just rub a dollop onto the skin, wherever the resin is, work it in like hand cream for a minute, then a quick rinse off with soap/ fairy liquid/ whatever and resin's gone. Couldn't believe what I was reading the first time, but gave it a go and it works- without mullering your skin.
baby oil, cheap stuff from aldi, rubbed and worked well into the black sticky gloop, washes off with plain soap and water, took ages to get the best stuff for geting rid of sitka crap cos I cut and mill tons  of the stuff, and some of the barrier cream from arco, the kind designed for ink and paint helps greatly
So to continue with my Sitka theme,
how long will they live?
how tall will they grow?
what girth might they achieve?
and what distances should I be leaving between the retained trees? (I forgot to measure, but probably  DBH's of 300mm ish)
mth
EDIT;
just checked, the stronger ones are easily 400mm DBH
Edited by difflock
Would not go in to sparse , there’s bands of what they call continuous cover for red squirrel etc in keilder that they never clear fell just thin , it’s pretty much a guarantee that it will blow when thinned..
Have climbed and dismantled them well over 40m ,recon where planted around 90 year ago... I think they would just keep on going height wise there are some monsters about !
prob about 4 acre,
I know which direction the prevailing wind comes from, and the direction of the windthrown trees is another clue.
I am winching out the thinnings & prepared to leave the  "felled/thinned" stuff that is ackward to access  on the ground for nature to take its course.
currently leaving about 3m between trees, suffice that the crowns are just still just interlocking
kinda a suck-it-and-see approach
I would be pleased to get another 20 years out of at least some of them.
mth
