  On 27/12/2017 at 15:59, wjotner said:
I have limited space to store. A tipping trailer would take up too much space and would prevent me using a chipper.
I think you're probably right on all points. But i want a 4x4. If it take 1 to 1.5 ton of chip, that would be enough for 90% of my jobs currently. So not worried about that. I'd consider getting a Ford Ranger tipper, or similar. But would they be able to carry as much as a landy 130 or 110 hicap?
Expand
Defenders do a job and they do it well.
Gearing is good for heavy towing. Air bags in the back will sort out the ride when fully laden.
They are also surprisingly reliable, I believe most of the issue comes with what people expect. A Hilux that's done motorway miles from new and maybe towed a little trailer every now and again is likely to have received less parts than a Defender of the same age and mileage that has been worked hard. Almost every defender I know is worked hard with heavy towing and regularly off road. The life of most double cab pickups and vans is definitely easier, from my personal experience.
Mine has towed full weight from brand new on almost every journey (nearly at 40000 miles now) and has been excellent. Is it comfy? not especially. But i have a car when comfort is a requirement.
Expand
So am I better off buying a pickup and converting it to a tipper (assuming its not been treated as badly) or just getting a tipper (which means less expense converting it to tipping) but being prepared to spend money to upgrade, improve, replace a worn out landy?
  On 27/12/2017 at 17:07, Joel77 said:
Do you need one or want one ? I do jobs where only a 4x4 is needed but 90% of my work is normal trucks
Expand
Bit off both to be honest. Probably want one more than I need it though.
Expand
How much do you have to spend?
I wouldn't want to run one without the 6 speed box, which means probably 18k+ for the base truck then 4-7k for the tipping gear.
Saying that, the TD5 engine is lovely. I just really like the newer ones
You’ll need to buy a HCPU then if your not able to build / convert a body yourself then find a firm that can
its as long as it is short, obviously building your own body lets you chose the design & spec
you could also streacth the chassis from 110 to 130 or even 140 etc
this is is the good thing about defenders, you can modify them ?
Expand
That's way outta my league. I'm talking about spending £5 to £7K max. Which basically means, buy a shit pick up for £3K and spend £2 or £3K on conversion, or buy an even shitter tipper for about £6 or £7K.
Expand
Stick with what you have if that's your budget.
  On 27/12/2017 at 21:00, htb said:
You,ll be looking at Tdi territory or rough TD5 then
Expand
Can that work? I'm not bothered about comfort or frills. I just need it to start, drive and not break down too often.
Read more
