Had to do a DPF regen this morning (bit naughty on a Sunday I know noise wise)
I didn’t realise these Tier 5 engines need to be used a bit and not mollycoddled, only 145 hours on it.
Stuck it behind the house for an house with the engine roaring till it had burnt off all the soot in the DPF.
Every day is a school day as they say.
3 hours ago, doobin said:
No reason it shouldn’t work if you can get the right size auger fittings or an adaptor. just be aware that if the power unit is direct mounted rather than free swinging you could side load it with a long auger into earth and reduce bearing life etc.
Thanks.
That's a good shout ref free swing 👍
I thought you were going to lift it out with the rootball and plant somewhere else.
Just because you have a MO you can keep moving the trees around on a whim, bit like bedding plants but bigger.
  • 3 weeks later...
On 14/05/2023 at 18:53, AHPP said:
I transplanted a pyracantha with the Skidster and a 3 tonne digger the other week. I hope it's died.
It died.
  • Haha 4
