Alexandr Fedoseev
Fail. Sling crash.
I think you would be surprised how often slings break all the big firms involved in steal construction don't use them.
I no it's quick but for anything of weight I'd be sticking to the chains all on the crane firm then.
Share this post
Link to post
I found slings much slow than chains which are quick to attach and then adjust.
I guess being steel they have a better cycle to fail rate, all our crane slings (used only in tree planting and with our hiab for lighter crane removals, are retired after a year sometimes they may only do a few lifts, they are cheap failures are not!
Share this post
Link to post
That's a great way to think about it. To many people in ours and probably other industries push things as far as possible before replacement.
Sent from my HTC One using Arbtalk mobile app
Share this post
Link to post
Bet that gave you a shock ! Don't suppose there is LOLER in Russia ? In the UK well last crane company I used they refused to let us work with our own slings despite being brand new and brought for the job.
Share this post
Link to post
Out of interest why was a crane being used since everything was being put at the bottom of the tree, and those pieces all looked lowerable?
Share this post
Link to post
Hmmh. In the offshore industry, chains are never used for lifting and rigging purposes. And for good reason....difficult to inspect properly without use of specialist non destructive testing techniques. Webbing and round slings are used a lot. But competent inspection is essential. For large loads wire slings are used.
But am I an expert................
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
