Sign in to follow this
karl1991
Cleaning krabs
I've always used warm soapy water, dried them out, then used graphite powder, but I've heard that's not a great idea?
The DMM's do seem to require a bit of love Darrin, for sure.
Joe I bought a DMM oval quad lock.
You need to grip it tightly, twist the shaft one way, ease it up towards the tip, twist it the other way then it opens up and the feeling is pretty intense.
Share this post
Link to post
That's what I do, any reason why it's not a great idea? I thought graphite powder was preferred over WD40 etc as dust/grit/etc didn't stick to it.
Share this post
Link to post
I've used a few different lubricants but for DMM Carabiners WD40 is my preferred choice.
This carabiner type is the worst i've had for sticking.
Duck oil is Recommended from DMM/Treemagineers.
Share this post
Link to post
I use warm soapy water, open and close the gates a few times under water, then leave to air dry. Usually that's enough but if not then duck oil if required.
DMM definitely say no to both graphite powder and WD40.
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
