Timberwolf Fins and flywheel bearings
Dean Lofthouse
  • 2 years later...
  • 5 years later...
Fly wheel bearings whent on my tw150 yesterday. Just bought full overhaul bearing kit being all confident about striping it down! but struggling at the first hurdle to get the thing apart!! Just read this post and am now thinking I should have left it to a professional How much should I expect to be paying for this to be done?? And does any one know any where near Gatwick area they can recommend?
  • 3 years later...
  • 3 years later...
Thank you for the brilliant guide on this
Has a fan go on the TW 150 last week so just stripped it down to inspect, will replace bearings/belts at same time
One query I have (first time I've been balls deep in a TW) on removal of the flywheel I can see the inner bearing race has chattered/worn into the backplate
The bearing has a bit of play but was nowhere near shot
Looking at the bearing housing there are no shims, but even so it sits proud but approx 0.4mm
Just hoped one of you might be able to advise if this is normal or something to address
Thanks all
Joe
  • 7 months later...
So 150 has a rumple and today a ticking noise coming from rotor housing, me thinking time to change bearings, when ordering part will I need to replace shafts. And do you need a hydraulic press to put bearings in.
Shafts are screwed together. Although sometimes damn tight.
Bearings can be knocked out and carefully knocked back in with a vice/soft hammer/big socket.
