Axe or maul
Jonathan Bundock
  • Replies 37
Depends on what would you are splitting. But I would prefer a maul over an axe as it is less likely to get stuck in knotty/gnarly wood. You can waste a lot of time trying to release your axe head when it becomes embedded in a log. Mauls come in different weights, so make sure you get one that you can manage for a full mornings splitting!
If your supply of wood is nice clean rings, then any old axe will do. The snottier they get, the better the axe/maul you'll need.
You can get half and half as well. Gransfors Bruk do a lovely range. They come razor sharp, literally. You can even shave with the maul. The beauty of having a really nice axe, that'll hold it's edge really well, is that it cuts as much as it splits. So you're not always relying on brute force.
Between us all here, I guess we have most of the range, including a couple of double headed throwing axes.
https://www.gransforsbruk.com/en/product-cat/splitting-axes/
For the range
https://www.gransforsbruk.com/en/product/gransfors-small-splitting-axe/
My favourite all rounder.
