I'm 45, and also semi retarded. I'm no Navy seal mind.
So what make n brand of short bus do you wheel your sharp tools about in mate?
Jomoco
  • Replies 296
Tranny.
I'm not allowed sharp tools, they are for the professionals.
Do they make you wear your helmet all the time too?
Hard to bear in this summer heat!
My tranny has a crawler gear too, we may be distant cousins!
Jomoco
Are there any papers or technical studies around about this, I have a team who are good but getting long in the tooth and at some point they will need to be replaced, but you only need to attend a woodfair with a climbing competition to know that age is no barrier!
Just curios to see if any studies have been made...
Jomoco
Could well be distant cousins, we both TALK a good job.
The older you get the less hard you have to work because you know all the little tricks to make easier.
There's a massive difference between spurring up and topping a conifer then ringing it down without a clear up, compared to a fiddlearse spurless reduction over four gardens, then dragging the brush through a tight passageway, with a bit of "help" from a stoned teenage groundy (with a two hour each way drive into central London)
The first you could do into your dotage, the second is a younger mans game.
Both tree work though.
